php/mapscript queryByRect on raster files
Andrea Marelli
maro.jam at TISCALI.IT
Mon Feb 13 10:18:38 EST 2006
Any hint?
i will hopefully wait...
Thanks!!
bye
Andrea
>Hi guys,
>i'm implementing queryByRect on raster files using php/mapscript.
>The script i've written (see following code) works well, but i have a little
>problem when i make queries on large areas...
>It seems that the getShape function uses a very large amount of memory on
>the server, so i put $shape->free(); but it seems to do nothing..
>Any suggestion on how to free shared memory on server?
> $query_rect = ms_newRectObj();
> $query_rect->setextent($westlon, $northlat, $eastlon, $southlat);
> @$layer = $map->getLayer(0);
> $return = $layer->queryByRect($query_rect);
> if($return == MS_SUCCESS){
> $num_results = $layer->getNumResults();
> $layer->open();
> for($i=0; $i<$num_results; $i++){
> $shape = $layer->getShape(0, $i);
> $values = $shape->values;
> // output
> echo $values['value_list'];
> echo '<br>';
> $shape->free(); // ??????
> unset($shape);
> unset($values);
> $layer->close();
> $map->freequery(0);
> $query_rect->free();
