Highlight image symbol
Xiaonan Zhang xnzhang11 at GMAIL.COM
Tue Feb 14 07:22:17 EST 2006
Thanks Bart.
I added a new layer to store the selection.
thanks.
On 13/02/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl>
wrote:
> Hi,
> I always draw the selection in a separate LAYER which is on top of the
> map, and then you can add a STYLE object to your CLASS with e.g. a circle
> symbol and set its color to the color you want for selection. The circle
> will need to be underneath your PIXMAP (watch your STYLE sequence).
> For that I use PHP/Mapscript.
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> *Van:* Xiaonan Zhang [mailto:xnzhang11 at gmail.com]
> *Verzonden:* maandag 13 februari 2006 15:49
> *Aan:* Eijnden, B. van den (Bart)
> *CC:* MAPSERVER-USERS at lists.umn.edu
> *Onderwerp:* Re: [UMN_MAPSERVER-USERS] Highlight image symbol
> Hi Bart,
> Do you mean I need to add code to draw a circle arount the selected
> feature?
> regards
> Jonathan
> wrote:
> > If your pixmap is transparent, you can draw a circle underneath using
> > the selection colour.
> > Best regards,
> > Bart
> > *Van:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]*Namens
> > *Xiaonan Zhang
> > *Verzonden:* maandag 13 februari 2006 15:36
> > *Aan:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Onderwerp:* [UMN_MAPSERVER-USERS] Highlight image symbol
> > Dear all,
> > I created one image symbol (pixmap) to a point layer. However I can not
> > highlight the selected features in that layer as the symbol is an image.
> > Is there anyway to solve this?
> > thanks.
> > Jonathan
> > Disclaimer
> > ************************************************************************ Aan
> > dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend
> > bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen,
> > wordt u verzocht het te vernietigen en de afzender te informeren. Wij
> > adviseren u om bij twijfel over de juistheid of de volledigheid van de mail
> > contact met afzender op te nemen. This message shall not constitute any
> > rights or obligations. This message is intended solely for the addressee. If
> > you have received this message in error, please delete it and notify the
> > sender immediately. When in doubt whether this message is correct or
> > complete, please contact the sender.
> Disclaimer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060214/1bc7e488/attachment.html
