Mapserver crashes while antialiasing
Torsten Weber TWeber at TRAFFIC-CONSULT.DE
Tue Feb 14 09:25:32 EST 2006
Hi Umberto,
thanks for your advice.
I've configured the apache on the SuSE 9.2 System to use php as a fastcgi prog
instead of the module. After solving some problems passing the oracle
environment to the cgi, I got the the same result as working with the moduled
version with the little difference that the php prog is now crashing.
I get the following error from the apache server every time I use the RGB
mode:
"Server error!
The server encountered an internal error and was unable to complete your
request. Either the server is overloaded or there was an error in a CGI
script."
8 Bit works fine but slow??.
Do you have some other ideas?
Regards
Torsten
Am Dienstag, 14. Februar 2006 10:17 schrieb Umberto Nicoletti:
> perhaps you are using php as a shared module?
> Note that php as a shared module is not supported and will quite
> likely cause crashes like those you are experiencing.
> Reagrds,
> Umberto
> On 2/14/06, Torsten Weber <TWeber at traffic-consult.de> wrote:
> > Hi all,
> > I'm using mapserver 4.6.2 and 4.8.1 on SuSE 9.2 and 10.0 with
> > php_mapscript. I've compiled both mapservers on both machines for using
> > oracle to get the spatial information. If I use 8Bit coloring all things
> > work fine (but no antialiasing). Within RGB mode the server gets
> > segmentation faults. But sometimes it works one or two times (don't know
> > why).
> > Versions:
> >  mapserver: 4.6.2 + 4.8.1
> >  SuSE Linux: 9.2 + 10.0
> >  php:   4.3.8 + 4.4.0
> >  oracle instantclient 10g
> >  apache: 2.0.50 + 2.0.54
> >  gd: 2.0.28 + 2.0.32
> > I'm using antialiasing on line and polygon Layers only. But there are
> > raster layers also.
> > Here is an example for both antialiased layers:
> > Polygon Layer using data from shape files.
> >   LAYER
> >     NAME "Gemeinden"
> >     PROJECTION
> >      "init=epsg:31467"
> >     END
> >     METADATA
> >       "DESCRIPTION" "Gemeinden"
> >       "RESULT_FIELDS"    "Name"
> >       "RESULT_HEADERS"    "Name"
> >                         "SELECTABLE" "false"
> >     END
> >     DATA "/srv/www/htdocs/geodata/Admin_Grenzen/Gemeinden"
> >     TYPE POLYGON
> >     TRANSPARENCY 50
> >     CLASS
> >       NAME "Gemeinden"
> >       TEMPLATE "void"
> >       STYLE
> >         COLOR 180 180 0
> >         OUTLINECOLOR 90 90 0
> >         SIZE 3
> >         ANTIALIAS TRUE
> >       END
> >     END
> >   END # Layer
> > Line Layer using oracle spatial data.
> >         LAYER
> >                 NAME "kanten"
> >                 PROJECTION
> >                         "init=epsg:31467"
> >                 END
> >                 DEBUG ON
> >                 CONNECTION "user/pass at oradb"
> >                 CONNECTIONTYPE oraclespatial
> >                 DATA "GEOLOC FROM (SELECT GEOLOC, ID, BEZEICHNUNG, ART,
> > TYP FROM STRECKEVIEW) USING UNIQUE ID"
> >                 TYPE LINE
> >                 SYMBOLSCALE 20000.0
> >                 METADATA
> >                         "DESCRIPTION"    "Straßen"
> >                         "RESULT_FIELDS"    "ID,BEZEICHNUNG,ART"
> >                         "RESULT_HEADERS"    "Nummer,Name,Typ"
> >                         "SELECTABLE" "true"
> >                         "LAYERDESC"             "Straßen"
> >                 END     # Metadata
> >                 CLASS
> >                         NAME "Autobahnen"
> >                         TEMPLATE "void"
> >                         EXPRESSION ([TYP]=21)
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 0 0 200
> >                                 SIZE 7
> >                                 ANTIALIAS TRUE
> >                                 MINSIZE 7
> >                                 MAXSIZE 18
> >                         END
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 255 255 255
> >                                 SIZE 4
> >                                 ANTIALIAS TRUE
> >                                 MINSIZE 4
> >                                 MAXSIZE 12
> >                         END
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 0 0 200
> >                                 SIZE 2
> >                                 MINSIZE 2
> >                                 MAXSIZE 5
> >                                 ANTIALIAS TRUE
> >                         END
> >                         LABEL
> >                                 ANGLE AUTO
> >                                 COLOR 256 0 0
> >                                 POSITION AUTO
> >                                 SIZE LARGE
> >                                 TYPE truetype
> >                                 FONT "verdana"
> >                         END #LABEL
> >                 END # Class
> >                 CLASS
> >                         NAME "Bundesstraßen"
> >                         TEMPLATE "void"
> >                         EXPRESSION ([TYP]=22)
> >                         #MAXSCALE 250000.0
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 50 50 50
> >                                 SIZE 5
> >                                 MINSIZE 5
> >                                 MAXSIZE 15
> >                                 ANTIALIAS TRUE
> >                         END
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 255 255 0
> >                                 SIZE 2
> >                                 MINSIZE 2
> >                                 MAXSIZE 10
> >                                 ANTIALIAS TRUE
> >                         END
> >                 END # Class
> >                 CLASS
> >                         NAME "Landesstraßen"
> >                         TEMPLATE "void"
> >                         EXPRESSION ([TYP]=23)
> >                         MAXSCALE 250000.0
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 50 50 50
> >                                 SIZE 5
> >                                 MINSIZE 5
> >                                 MAXSIZE 15
> >                                 ANTIALIAS TRUE
> >                         END
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 250 250 250
> >                                 SIZE 2
> >                                 MINSIZE 2
> >                                 MAXSIZE 10
> >                                 ANTIALIAS TRUE
> >                         END
> >                 END # Class
> >                 CLASS
> >                         NAME "Kreisstraßen"
> >                         TEMPLATE "void"
> >                         EXPRESSION ([TYP]=24)
> >                         MAXSCALE 75000.0
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 50 50 50
> >                                 SIZE 3
> >                                 MINSIZE 3
> >                                 MAXSIZE 10
> >                                 ANTIALIAS TRUE
> >                         END
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 250 250 250
> >                                 SIZE 1
> >                                 MINSIZE 1
> >                                 MAXSIZE 6
> >                                 ANTIALIAS TRUE
> >                         END
> >                 END # Class
> >                 CLASS
> >                         NAME "Sonstige"
> >                         TEMPLATE "void"
> >                         EXPRESSION ([TYP]<21 OR [TYP]>24)
> >                         MAXSCALE 50000.0
> >                         STYLE
> >                                 SYMBOL "lstandard"
> >                                 COLOR 100 100 100
> >                                 SIZE 1
> >                                 #ANTIALIAS
> >                                 MINSIZE 1
> >                                 MAXSIZE 10
> >                                 ANTIALIAS TRUE
> >                         END
> >                 END # Class
> >         END # Layer
> > Used outputformat:
> >         OUTPUTFORMAT
> >           NAME pngrgb
> >           DRIVER "GD/PNG"
> >           MIMETYPE "image/png"
> >           IMAGEMODE RGB
> >           FORMATOPTION  INTERLACE=OFF
> >           TRANSPARENT OFF
> >         END
> > It doesn't matter if I use GIF or jpeg instead.
> > Is anyone out there, who could help me?
> > Many thanks and best regards
> > Torsten
T. Weber      E-Mail: TWeber at traffic-consult.de, TWeber at weber-sys.de
Traffic Consult GmbH        Herzbachweg 65          63571 Gelnhausen
Tel: 06051 / 82889-15  Mobile: 0179 / 5340731  Fax: 06051 / 82889-29
E-mail: info at traffic-consult.de   WWW: http://www.traffic-consult.de
