projection error when mode=itemquery
Vito Meuli vito.meuli at TECNOLOGIEAVANZATE.IT
Tue Feb 14 11:42:14 EST 2006
Hi Rich! Hi listmates!
I have the same problem.
It seems that when I use "mode=itemnquery" the raster displays always in the
same position and with the same magnification in the final image (like
"TRANSFORM FALSE" layers), whereas the vector layers follow the zoom and pan
correctly.
I'm using Mapserver 4.6.2 on a Red Hat Enterprise Linux AS 4, compiled like
almost all needed libraries.
I'll give a try to Mapserver 4.8.1 as soon as possible.
Any ideas?
Thanks!
Vito
Alle 01:24, mercoledì 7 settembre 2005, Richard Greenwood ha scritto:
> I think I've got a bug here, but I'll throw it out to the list before
> I file a bug report.
> I have a map with a state plane (U.S. Foot) projection defined. It
> includes a UTM (meters) raster layer. All displays well until
> mode=itemquery or itemnquery, or queryfile=... In these modes the UTM
> raster layer occupies only a small portion of the rendered map (see
> attached image).
> I have tested in two different state plane zones with two different
> raster UTM image sets, with mapserver versions 4.2, 4.6 and 4.7.
> Any ideas?
> Thanks,
> Rich
Ing. Vito Meuli
Tecnologie Avanzate s.r.l.
via B. Croce, 49
70015 Noci (BA)
tel. 080-4979652
fax. 080-4979263
email: v.meuli at tecnologieavanzate.it
http://www.tecnologieavanzate.it
http://www.taonline.it
