Oracle-Connection-Pooling in Java
Fernando Simon
fsimon at UNIVALI.BR
Wed Feb 15 09:12:31 EST 2006
Hi all,
I'm working to solve this bug too.
I'm trying to find the core of the memory leak. I will need to share
information with Umberto about the bugs.
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Umberto Nicoletti wrote:
> I am now working on issue #1662.
> Issue #1164 details how I am trying to tackle the memory leaks: with
> unit tests which run a significantly smaller portion of the code. In
> fact the ones in the patch run *only* the connection pooling
> functions, so it should be MUCH easier to use a debugger and trace
> them.
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1664
> BTW: Benedikt, what did you use, if you did, to trace memory leaks?
> Regards,
> Umberto
> On 2/13/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
>> On 2/13/06, umn-ms at hydrotec.de <umn-ms at hydrotec.de> wrote:
>>> Umberto
>>> Thank you for taking care onon this old but still open issue!
>>> I created
>>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1661 and
>>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1662
>>> Benedikt
>>> (Sorry! I was not able to add your e-mail-adress to cc. Bugzilla denied to
>>> do so. I suppose
>>> you can handle this anyway.)
>> I just did. I will send you a patch for the
>> msConnPoolCloseUnreferenced function asap o that you can test it.
>> Regards,
>> Umberto
>>> Umberto Nicoletti <umberto.nicoletti at gmail.com> schrieb am 13.02.2006
>>> 10:25:02:
>>> > Benedikt,
>>> > since I am looking this issue would'n t you mind opening a bug for the
>>> > inclusion of msConnPoolCloseUnreferenced in mapscript and one for the
>>> > memory leaks (add me to the cc list)?
>>> > Reagrds,
>>> > Umberto
>>> > On 1/2/06, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
>>> > > Hi list members,
>>> > > From former threads I got the impression, that there are some folks
>>> > > interested in the Oracle/Mapserver/Java/Tomcat.
>>> > > Therfore I'd like to share experiences I made with using
>>> Connection-Pooling
>>> > > of
>>> > > Oracle-Connections inside Java/Tomcat.
>>> > > Testenvironment: Mapserver 4.6.2; Suse-Linux; Tomcat 4.1.31; Sun-Java
>>> 1.4.2
>>> > > Simulating 5 Browsers, which produce maps, query features, make
>>> selections,
>>> > > query-legend-pics frequently.
>>> > > - After using synchronized "enough" I didn't have crashes of Tomcat.
>>> > > - Big memory leak: Between the first 5 requests and the next 100
>>> requests
>>> > > the Tomcat-process became about 400MB bigger. (I use "top" for
>>> > > watching memory-footprint.)
>>> > > - Cleaning the Connection-Pool "by hand". This means:
>>> > > Opening the function msConnPoolCloseUnreferenced in mappool.c
>>> > > for use in Java and call it after every request.
>>> > > - After this I still have memory leaks: About 100MB for 30.000
>>> requests.
>>> > > (I also made a test: 25.000 requests without Connection pooling.
>>> Memory
>>> > > increased
>>> > > and decreased as expected in this case.)
>>> > > - Performancecomparison in my testcase:
>>> > > Without use of connection-pooling: ~ 50 Request per minute
>>> > > With use of connection-pooling: ~75 Request per minute
>>> > > As a result I have the following encouragements:
>>> > > - Making msConnPoolCloseUnreferenced availabe for mapscript via swig.
>>> > > (I made a hack by directly editing mapscript/java/mapscript_wrap.c
>>> and
>>> > > Java-Files in
>>> mapscript/java/edu/umn/gis/mapscript.) I
>>> > > think this
>>> > > function could be part of the mapscript-Object?
>>> > > - Investigations on the memory leaks. Both leaks shouldn't occure.
>>> (I'll do
>>> > > this, if I find time. but ...)
>>> > > - Fernando Simon: What about using OCI-Connection-Pooling for oracle
>>> > > instead the mappool.c?
>>> http://oraclesvca2.oracle.com/docs/cd/B14117_01/appdev.101/b10779/oci09adv.htm#452244
>>> > > (If you don't have time, I maybe could help coding. But would it
>>> become
>>> > > part uf Mapserver?)
>>> > > Happy new year to everybody
>>> > > Benedikt Rothe
