Mapserver 4.8.1 linux installation problems
Neil "Nemo" Martinko nemo at IRONCOUNTYFOREST.ORG
Wed Feb 15 09:27:35 EST 2006
Be sure to check the permissions of the file.  While in the /var/www/cgi-bin
directory...
"ls -l"
There should be a line for your mapserv file like this...
"-rwxr-xr-x  1 nobody nobody 754320 Feb  6 10:28 mapserv"
If you have different permissions, run...
"chmod a+rx mapserv"
If you have different owner/group (the "nobody nobody" above)...
"chown nobody.nobody mapserv"
Rather than running just "./mapserv", it's better to run "./mapserv -v".  It
will output the version and supported inputs/outputs.
As for yum, it would be nice if somebody created a repository for apt/yum
access of MapServer, GRASS, QGIS, and all their needed dependencies.  I
haven't found one, yet.  It is possible, it just hasn't been done.
Nemo
