PHP/MapScript: How to add a point as an inline feature ?
    Daniel Morissette
    dmorissette at DMSOLUTIONS.CA
    Wed Feb 15 06:46:05 PST 2006
Lars V. Nielsen (Hvenegaard) wrote:
> Appararently setting  $layer->set("transparency",MS_GD_ALPHA)  in MapScript
> trashes the mapfile layer setting  TRANSPARENCY ALPHA, rendering the symbols
> in the layer non-transparent. !??
Lars,
I see in your previous email that you're using version 4.5. The constant
MS_GD_ALPHA was added to PHP MapScript only in 4.6.0-beta1. You will
have to either upgrade, or use "$layer->set("transparency", 1000)" (1000
is the internal value of MS_GD_ALPHA).
BTW, while checking that, I noticed an issue with the msSaveMap()
function in its handling of TRANSPARENCY ALPHA, but that should not be
related to the problem that you describe above:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1669
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
More information about the MapServer-users
