wms howto
Travis Kirstine GIS Tech
tkirstine at JDBARNES.COM
Wed Feb 15 13:30:28 EST 2006
Bart,
Your suggestion worked like a charm. Do you know where I could find a
complete list of wms commands. I've tried the mapserver documentation but
it dosen't include wms_extent for example. I've tried to set the status off
using "wms_status" "off" but that dosen't work
-----Original Message-----
From: Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
Sent: Wednesday, February 15, 2006 12:39 PM
To: Travis Kirstine GIS Tech
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] wms extent
Yes there is, set the wms_extent METADATA on that LAYER.
Best regards,
Bart
Travis Kirstine GIS Tech wrote:
>When I add a mapserver based wms to ArcMap or uDig the map extent defaults
>to the max xy and min xy of my largest layer in my mapfile (Ontario)instead
>of the extent defined in my mapfile (toronto). Is there a way to force the
>EXTENT defined in the mapfile?
>Travis Kirstine
>First Base Solutions Limited
>140 Renfrew Dr, Suite 100
>Markham ON
>L3R 6B3
>Phone 905.477.3600
>Fax 905.477.3882
>tkirstine at jdbarnes.com
OSGIS, Open Source GIS
http://www.osgis.nl
