MapScript SetSymbolSet
Sean Gillies sgillies at FRII.COM
Wed Feb 15 19:15:52 EST 2006
Oh, I see. Yeah, it's possible. Here's an example from one of my
Python projects:
     circle = mapscript.symbolObj('circle')
     circle.type = mapscript.MS_SYMBOL_ELLIPSE
     circle.filled = mapscript.MS_TRUE
     line = mapscript.lineObj()
     line.add(mapscript.pointObj(1,1))
     circle.setPoints(line)
     circle.sizex = 1
     circle.sizey = 1
     mo.symbolset.appendSymbol(circle)
The "mo" name is bound to a mapObj. It's very important to get sizex
and sizey right, should be the width and height of the symbol in the
same units as the point and line coordinates used to construct the
symbol.
To use this symbol
     style.symbol = mo.symbolset.index('circle')
Translate this into C# and you should be good to go.
cheers,
Sean
On Feb 15, 2006, at 5:03 PM, Christopher Condit wrote:
> Hi Sean-
> Is there a way to accomplish this with MapScript?  All I see is a
> way to
> set the symbolset.
> Thanks,
> Chris
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-
> USERS at LISTS.UMN.EDU] On
> Behalf Of Sean Gillies
> Sent: Wednesday, February 15, 2006 3:58 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] MapScript SetSymbolSet
> On Feb 15, 2006, at 3:19 PM, Christopher Condit wrote:
>> Hi Julien-
>> Thanks for your response.  Here are the contents of the symbol file:
>> SYMBOLSET
>>   SYMBOL
>>     NAME 'circle'
>>     TYPE ELLIPSE
>>     POINTS 1 1 END
>>     FILLED TRUE
>>   END
>> END
>> The problem I'm having is intermittent and I can't reliably reproduce
>> it.  My only thought was that for some reason mapscript couldn't read
>> the file.  Is there any way to embed these symbols directly in the
>> mapfile instead of referencing the symbolset file?
>> Thanks,
>> Chris
> Yes, just add any SYMBOL block as a child of the top-level map.
> Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
