hi
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Thu Feb 16 04:16:45 EST 2006
No you cannot use PHP/Mapscript as a WMS/WFS server (out of the box). You
need Mapserv CGI for that. You can consume WMS and WFS services as a WMS/WFS
client though with Mapscript.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Shoaib Burq
Verzonden: donderdag 16 februari 2006 10:15
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] hi
> What I sometimes do is develop a web site completely with PHP/Mapscript,
> but also use Mapserv CGI to provide OGC:WMS and OGC:WFS on my data.
Bart, does PHP/Mapscript not have API support for OGC:xxx ?
--shoaib
> Best regards,
> Bart
> Puneet Kishor wrote:
> > On Feb 12, 2006, at 12:39 PM, Bart van den Eijnden (OSGIS) wrote:
> >> Yes you can.
> >> Best regards,
> >> Bart
> >> Neelima Doddapaneni wrote:
> >>> HI all
> >>> Can I use both cgi mapserver and php mapserver in parallel.
> >>> Regards,
> >>> Neelima
> > well, a little qualifier required there, because the OP was a bit
> > unclear to me. If "by parallel" you mean serving one website using
> > MapServer CGI, and another using MapServer/PHP MapScript, both on the
> > same computer, then yes, you can.
> > On the other hand, if you are asking whether you can power a single
> > website using two server-side technologies (CGI and PHP-MapScript),
> > then the simple answer would be "no."
> > Puneet Kishor
> OSGIS, Open Source GIS
> http://www.osgis.nl
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
