Variable Substitution in Postgis Query
Maurizio Esposito
m.esposito at SOFTEC-SRL.COM
Thu Feb 16 09:45:39 EST 2006
Ciao Umberto
hi list
this is the query where substitution doesn't work:
DATA "the_geom from buildings"
FILTER "buildings.pk_id NOT IN (SELECT feat_id FROM feat_vis WHERE
feat_vis.ruolo='%ruolo%' AND feat_vis.layer='buildings')"
The table feat_vis is used as an exclusion list with the following
attributes:
ruolo
layer
feat_id
and if I substitute %ruolo% with a string value, i.e. 'technician' the
query works fine
Thank you
Maurizio
