Problem drawing lines
blaise
bpicinbono at WORLDONLINE.FR
Thu Feb 16 15:20:10 EST 2006
On Thursday 16 February 2006 19:55, Chip Taylor wrote:
> I have a map file that is supposed to draw streets from a shapefile. Of
> course, the shape file has many segments per street. Mapserver 4.6 renders
> the streets with gaps in the continuity of the line. The same shapefile
> displayed in ArcMap shows no gaps. Can you tell me what is the problem?
> Here is the mapfile:
> # This is the Washington State map file
> NAME "wamap"
> UNITS DD
> EXTENT -127.00 43.00 -115.00 50.00
> SIZE 475 475
> IMAGECOLOR 189 202 222
> IMAGETYPE GIF
> SHAPEPATH "../Shape_Files"
> FONTSET "../fontset.txt"
> # Symbol for drawing cartolines
> SYMBOL
> NAME "cartoline"
> TYPE cartoline
> LINECAP butt
> LINEJOIN miter
> LINEJOINMAXSIZE 1
> END
> # Web object
> WEB
> TEMPLATE "../HTML_Files/sitemap.html"
> IMAGEPATH 'd:/wwwroot/tmp/'
> IMAGEURL "/tmp/"
> END
> # Washington State Road layer - Local Roads (test)
> LAYER
> NAME "testRoads"
> DATA "US_States/Washington/Roads/CountyRoads"
> status default
> TYPE line
> CLASS
> NAME "Interstate Hwy"
> STYLE
> SYMBOL "cartoline"
> SIZE 3
> COLOR 241 151 91
> END
> END
> END
> END # mapfile
Perhaps because of your symbol definition ? What does it display with
SYMBOL 0
or
SYMBOL 1 ## (or more)
(to use the default point symbol) ?
Blaise
