GD LIBRARY
Clint Johnson cjohnson at REFRACTIONS.NET
Thu Feb 16 18:20:27 EST 2006
Download the sources at
http://www.boutell.com/gd/http/gd-2.0.33.zip
Compilation for UNIX is fairly straight forward.
Compiling on windows with Visual Studio will take some work, as you will
need to create a new library project and correctly configure  it (via
project options) to generate either a static library or DLL (see gd.h
for the compile time directives).
Clint
Clint Johnson
Refractions Research Inc.
Cjohnson at refractions.net
Fabio D' Ovidio wrote:
> Dear list,
> I want to compile GD library on windows 2000.
> The zip package has only the DLL and a .bat file to convert the dll in
> lib for mapserver.
> I'd like to compile GD from source (because I have to use a different
> compiler and linker)
> so I need the source files for Windows and \ or a makefile.
> How can I do ?
> Thank u
> */Fabio D'Ovidio/*
> */Planetek Italia Srl/*
> */via Massaua 12, Bari -70123 Italy/*
> */e-mail : /**/_dovidio at planetek.it_/*
> */_http://www.planetek.it_/*
