Scale bar
Steve Lime
steve.lime at DNR.STATE.MN.US
Fri Feb 17 18:12:33 EST 2006
I notice you haven't set the overall map UNITS. The default is METERS.
If that's not correct then that could lead to all sorts of discrepancies...
Steve
>>> Ramesh Karra <karrarm at YAHOO.COM> 02/17/06 4:19 PM >>>
I would like to know how SCALEBAR object works. I would like to know if
the length of the scalebar drawn depends on the extent of the map.
When I use the following map file, the scale bar draws a line of about
2cms length and shows it as 1 inch! I feel this is not right because the
initial extent covers more than 10 inches of geographical area. What am I
missing here?
Thanks in advance
Ramesh
MAP
IMAGETYPE PNG
EXTENT 10.3605 5.309 10.609 5.507
SIZE 600 450
SHAPEPATH "/ms4w/"
IMAGECOLOR 225 225 225
FONTSET "/ms4w/apps/ms101/fonts/fonts.list"
SYMBOLSET "c:\ms4w\symbols.sym"
TEMPLATEPATTERN 'tm*'
WEB
TEMPLATE 'xxx'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END # Every object in MapServer must have an END.;)
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 200 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS INCHES
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END # Scalebar object ends
END
