ogrtindex and directory structure
Aaron Racicot
aaronr at ECOTRUST.ORG
Fri Feb 17 18:28:55 EST 2006
Not sure what environment you are in, but on Linux I do stuff like:
find . -name "*.shp" -exec ogrtindex -f "ESRI Shapefile" tindex.shp {} \;
This will recurse from the current directory (i.e. mapdata) and find all of the shapefiles and add them to the new tindex.shp file.
Hope this helps.
A
| Aaron Racicot | aaronr at ecotrust.org |
| GIS Programmer | 503.467.0759 |
| e c o t r u s t |
| Jean Vollum Natural Capital Center |
| 721 NW Ninth Avenue |
| Suite 200 |
| Portland, OR 97209 |
| www.ecotrust.org |
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Hunter, David - St. Louis Park, MN
Sent: Friday, February 17, 2006 3:11 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ogrtindex and directory structure
I need to tile index several layers for 50 states. If my directory structure looks like this:
/mapdata
/AK
/WY
/wy001/Parks.shp, water.shp, etc.
/wy045/Parks.shp, water.shp, etc.
Is there any way to create tile index files at the /mapdata/ directory that point to all the /state/county subdirectories? The ogrtindex utility doesn't seem to have the ability to recurse the directory tree. I could copy all park files into a /mapdata/parks/ directory, I suppose, and then index all the files in the directory, but that would put several thousand files into a single directory, which is a bit unmanageable and ugly. Anybody else come up with a solution to this problem?
David S. Hunter
Sr. Software Engineer
Fidelity National Geographic Solutions
division of Fidelity National Financial
5353 Gamble Drive, Suite 201
St. Louis Park, MN 55416
š Email: david.hunter at fnf.com
' Phone: 952.542.1440 ext. 256
7 Fax: 952.542.3859
