Failed connect to Oracle DB
NBolbot (sent by Nabble.com)
lists at NABBLE.COM
Mon Feb 20 04:31:55 EST 2006
Hello everybody,
I have my problems to get data from Oracle Database.
I use compilied version of mapserver for C#. There is no problems to draw a
picture using test-shapefiles. But when I trying to draw data from Oracle
Database I get an empty picture without any error message.
I use following map-file:
NAME DEMO
STATUS ON
SIZE 400 400
EXTENT 1 1 200 200
UNITS METERS
IMAGETYPE GIF
IMAGECOLOR 255 255 255
# Start of web interface definition
WEB
MINSCALE 1
MAXSCALE 100
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
LOG "/tmp/ms_tmp/gmap.log"
END
# Start of layer definitions
LAYER
NAME test
TYPE LINE
CONNECTIONTYPE oraclespatial
CONNECTION "myuser/test at test"
DATA "Geometry FROM MyTable using srid = 1000005"
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR 255 0 255
END
END
END
END # Map File
What configuration should I make to work with Oracle Database?
View this message in context: http://www.nabble.com/Failed-connect-to-Oracle-DB-t1154157.html#a3027692
Sent from the Mapserver - User forum at Nabble.com.
