Specifying MINDISTANCE for point features of a shapefile???
Steve Lime
steve.lime at DNR.STATE.MN.US
Mon Feb 20 15:55:46 EST 2006
If you use an an ANNOTATION layer type instead of a POINT you should be ok. ANNOTATION layers link the point symbol with the text so the MINDISTANCE set in the text label is honored. You may want to pre-sort your city shapefile based on population if possible (in ascending order) so that the largest cities gain preference.
Steve
>>> "Hudson, Mark (xwave)" <Mark.Hudson at XWAVE.COM> 02/20/06 2:22 PM >>>
Hello:
I have a shapefile of cities (represented by points obviously), and I
want to tell Mapserver to draw features a minimum distance apart - just
like the MINDISTANCE parameter of the LABEL object. The cities
shapefile covers a large area, so I want to display the layer at small
scales. However, at this scale some cities appear very close to one
another - and actually overlap. Can I tell Mapserver to not do this
and only draw them when there is a specified distance between features?
Thanks, Mark Hudson.
