Problems with join
DJ Broerse dennisjan at IBUILDINGS.NL
Tue Feb 21 05:52:30 EST 2006
Hi list and Steve
List: thanks or the replies.  Now I probably know what the problem is.
Steve: below there is a description of my problem.
I think the bottleneck in my problem are the templates. I use Pmapper as
a graphical interface and MapServer is the engine.
Pmapper doesn't care about the templates in the mapfile. That's the
reason why there is a meaningless string after the template key in the
mapfile (without this meaningless string there are no results)
Pmapper gets his results by using the following functions
$qRes = $this->qLayer->getResult($iRes);
$qShape = $this->qLayer->getShape($qRes->tileindex,$qRes->shapeindex);
$this->tempGridResult .= $this->printGridResultRow($qShape);
So I have another set of questions:
- Does mapserver require a template if I want to use joins?
- Is it possible to get the join data without using a template and using
some functions?
Thanks in advance,
Dennis-Jan
DJ Broerse wrote:
> I have two dfb files: gbkn-philippine and eigenaren
> The reference is gbkn-philippine.willekeur and eigenaren.aa_linkid
> What I want is if I query the the layer then I like to see the data of
> eigenaren.dbf .
> I can't figure out what is wrong.
> Maybe I have to use CONNECTION or CONNECTIONTYPE but I don't know what.
> TEMPLATE isn't necessary  because I use a one-to-one relation I think.
> I really hope you can help me
> Dennis-Jan
>  LAYER
>    NAME "gbkn-philippine"
>    TYPE line
>    STATUS ON
>    DATA "join/gbkn-philippine"
>    MAXSCALE 25100
>    METADATA
>      "DESCRIPTION" "gbkn-philippine"
>    END  # Metadata
>    JOIN
>     NAME "join1"
>     TABLE "gisdata/join/eigenaren.dbf"
>     FROM "WILLEKEUR"
>     TO "AA_LINKID"
>     TYPE ONE-TO-ONE
>    END
>    CLASS
>      Name "gbkn-philippine"
>      COLOR 249 49 249
>        TEMPLATE queryzichtbaar
>      SYMBOL "vet"
>      SIZE 2
>    END  # Class
>  END  # Layer
> Hey Steve
DJ Broerse dennisjan at ibuildings.nl
Direct: 0118 42 95 68 Mobiel: 06 48 01 03 08
Skype: callto://dennisjan-ibuildings
Ibuildings.nl BV - Information technology
http://www.ibuildings.nl - 0118 42 95 50
