ESRI ASCII GRID format
Francesco Sozzi
fsozzi at INTERCAD.CH
Tue Feb 21 09:30:22 EST 2006
Thank you for fast answer, I will take a try
Best regards
Francesco
----- Original Message -----
To: "Francesco Sozzi" <fsozzi at INTERCAD.CH>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, February 21, 2006 3:19 PM
Subject: Re: [UMN_MAPSERVER-USERS] ESRI ASCII GRID format
> Francesco Sozzi wrote:
>> Hi all,
>> Anybody knows if are there any way to show ESRI ASCII GRID FILES with
>> mapserver?
> Francesco,
> They should work "out of the box" if you have GDAL support built in. Just
> put the name of the grid file in your DATA statement like for any raster
> file.
> Now, there may be an additional issue. ESRI ASCII Grid files are often
> not
> 8bit. That is the raster values are often outside the range 0-255. If
> this
> is the case, special issues around scaling the values for display apply.
> You
> should read the Raster Access HOWTO to know more about how to deal with
> this
> though the brief solution is often fine to get something on the screen:
> The brief solution is add the following in your raster layer.
> PROCESSING "SCALE=AUTO"
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
