Lining up tiles and styling
Graham Davis
gdavis at REFRACTIONS.NET
Tue Feb 21 14:44:11 EST 2006
Stephen is correct, and the kamap code uses a buffer around each tile to
get around this issue. I've worked with some modified Kamap code, and
it uses the GD library to cut up the tiles, with a buffer not only
around each tile but also around the main metatile that is fetched from
Mapserver. Our setup uses a 10 pixel buffer around each tile, and twice
that for the buffer around the metatile.
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
Stephen Woodbridge wrote:
> Ed,
> Have you looked at http://ka-map.maptools.org/
> This is a google like AJAX client that uses php and mapserver on the
> backend to generate tiles. Even if you do not want to use the whole
> thing, you might look at tile.php to see how they resolve these issues.
> -Steve W.
> Ed Dowding wrote:
>> I'm tiling mapserver tile requests to form a map. On those tiles are
>> lines
>> styled with a thickness. The lines also have rounded ends.
>> Which means that when a line goes off the edge of a tile, they're
>> "rounding-off" making it impossible to tile from separate requests.
>> Quite difficult to explain, so here's a picture..
>> http://citysafe.org/temp/mapRounding.png
>> One approach would be to get mapserver to draw the line beyond the
>> extent of
>> its tile... but this is, I think, hypothetical, since I cant see that
>> it's
>> possible from the docs.
>> Does anyone have any experience of this?
>> Thanks in advance,
>> Ed
