laodForm() error
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Feb 21 15:35:40 EST 2006
You should have exactly 4 values for any extent value. This error means you
had more or less. Typically you see it if:
- the extent is provided using a delimeter other than a space
- the extent is not properly escaped in the URL (spaces must be turned into +'s or %20's)
Check those first.
Steve
>>> Khaled Kamoun <khaled.kamoun at GMAIL.COM> 02/21/06 8:04 AM >>>
what does this error mean : "loadForm(): Web application error. Not enough
arguments for imgext."
Khaled KAMOUN
