Trying to figure out epsg for a GeoTIFF
Dennis Megarry
dennis at MEGARRY.COM
Tue Feb 21 19:48:27 EST 2006
I'm going to sound like as complete newbie be assking this (which I am
really).
I have a GeoTIFF raster image and I'm not sure how to setup the projection
in my map file. Can someone take a look at the below info from gdalinfo
and tell me what I need to do? If at all possible, some details so I can
learn a bit?
Driver: GTiff/GeoTIFF
Size is 11873, 8123
Coordinate System is:
PROJCS["unnamed",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree (supplier to define
representation)",0.01745329251994328],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",38.6666666666667],
PARAMETER["standard_parallel_2",33.33333333333337],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-81.45000000000009],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-439988.052575,241474.587546)
Pixel Size = (63.88386800,-63.88386800)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( -439988.053, 241474.588) ( 84d48'17.02"W, 1d46'42.74"N)
Lower Left ( -439988.053, -277454.072) ( 84d40'25.94"W, 2d 7'20.21"S)
Upper Right ( 318505.112, 241474.588) ( 79d 1'15.86"W, 1d48'22.30"N)
Lower Right ( 318505.112, -277454.072) ( 79d 6'57.06"W, 2d 5'48.28"S)
Center ( -60741.470, -17989.742) ( 81d54'14.71"W, 0d 8'11.59"S)
Band 1 Block=11873x1 Type=Byte, ColorInterp=Palette
