Itasca demo and Ms4w
Pericles S. Nacionales
naci0002 at UMN.EDU
Wed Feb 22 09:46:45 EST 2006
The message you got means there's some obsolute KEYWORD values in the
mapfile. I don't have the demo files in my computer so if you can post
the few lines above and below line 44, I might be able to help.
As an aside, you can certainly put the demo files under
/ms4w/apache/htdocs. Or you might as well follow the way it's done in MS4W:
1. unzip demo under /ms4w/apps/
2. create a file called httpd_demo.conf (or whatever you want to called
it, just make sure to prepend with httpd_) and add these lines to it:
#This is the Apache config file for the MapServer Demo application.
Alias /itasca "/ms4w/apps/itasca"
<Directory "/ms4w/apps/itasca">
AllowOverride None
Options Indexes MultiViews
Order allow,deny
Allow from all
</Directory>
3. Restart Apache service
4. Edit the demo_init.html and relevant files and replace the paths with
the proper ones
5. Check that the demo is running at http://localhost/itasca.
Good luck!
-Perry
D. Eric Keefauver wrote:
> New and just getting started with ms4w on my local windows machine
> Where should one dump the itasca files to get the demo up and running:
> C:\ms4w\Apache\htdocs?
> I have placed the itasca data in the following:
> C:\ms4w\Apache\htdocs\mapserver_demos\itasca
> And within the map file I changed this line to:
> # change this value to match your setup
> WMS_ONLINERESOURCE
> "http://localhost/mapserver_demos/itasca/demo_init.html"
> At: http://localhost/mapserver_demos/itasca/demo_init.html and clicking
> the Initialize button I get the following error
> getString(): Symbol definition error. Parsing error near (none):(line 44)
> what am I doing wrong?
> thanks in advance and bearing with a complete newbie
> Eric
