[4.6.1 TO 4.8.1]: Problems with PNG and PHP/MapScript?
Aaron Koning aaronkoning at GMAIL.COM
Wed Feb 22 18:54:44 EST 2006
This could be a number of things. Are you editing your files in windows and
then transfering them to Linux? Could be incompatible line endings. Are you
including a shebang line in your PHP scripts? Could be a problem with odd
characters in the shebang line. Could be a problem with the new php.ini file
and the doc_root variable.
Have you tried creating a simple PHP script and testing, followed by a
simple PHP-MapScript script (and testing)?
Aaron
On 2/22/06, Sebastian Albrecht <albrecht at fielax.de> wrote:
> Hello,
> I just wanted to change from 4.6.1 to 4.8.1 because I've read the
> querymapObj is available in PHP/Mapscript since 4.8.
> So what I did was taking my old configure line from 4.6.1 and using it
> for the new version:
> ./configure
> --enable-force-freetype1
> --with-gd=/usr/local
> --with-zlib
> --with-jpeg
> --with-tiff
> --with-png
> --with-xpm=/usr/X11R6
> --with-threads
> --with-proj=/usr/local
> --with-php=/usr/local/src/php-5.0.4
> --with-gdal=/usr/local/bin/gdal-config
> --with-ogr=/usr/local/bin/gdal-config
> --with-postgis=/usr/local/pgsql/bin/pg_config
> --with-wfs
> --with-wcs
> --with-wmsclient
> --with-wfsclient
> --with-curl-config=/usr/local/bin/curl-config
> The compiling finishes without errors but all my MapScript applications
> which use PNG as output format don't work.
> It says "INTERNAL SERVER ERROR"
> which is "Premature end of header in /usr/local/bin/php".
> My PHP version is 5.0.4 which uses the same GD (2.0.33) installation as
> MapServer. And it worked with 4.6.1 without problems.
> Anybody had a similar problem or knows what to do?
> Sebastian
|  Aaron Koning
|  Information Technologist
|  Prince George, BC, Canada.
|  http://datashare.gis.unbc.ca/fist/
|  http://datashare.gis.unbc.ca/gctp-js/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060222/57172b4c/attachment.html
