Postgis and EXPRESSION
Stefan Schwarzer stefan.schwarzer at GRID.UNEP.CH
Thu Feb 23 05:33:48 EST 2006
Hahaha. That was a good one. Thanks a lot. Quite right. I actually
tried it before, but like ['reg_name']... didn't know (and didn't
understand) that the apostrophes should be around the bracktes...
Thanks!
Stef
>>         CLASS
>>             NAME ''
>>                 EXPRESSION ([reg_name] ne 'Africa')
> Don't forget to put quotes around [reg_name]. Aren't you trying to
> do a string comparison between the value of reg_name and "Africa"?
> Well, then you'll need them as Mapserver simply replaces [reg_name]
> with it's actual value before evaluating the expression.
> So, I suggest giving a try to somewhat like this:
> EXPRESSION ('[reg_name]' ne 'Africa')
