How to determine the scale
Ramesh Karra
karrarm at YAHOO.COM
Thu Feb 23 16:49:14 EST 2006
Thanks Ed,
Thank you very much for the quick response. How do I convert my lat/long
to a different projection, say LAEA? When I do this conversion, all my
shape files need to be re-created with this new projection co-ordinates,
right?
I have searched on the web, but could not figure out a way to convert
lat/long to LAEA. I really appreciate any pointers related to this.
Thanks
Krishna
On Thu, 23 Feb 2006 15:38:50 -0500, Ed McNierney <ed at TOPOZONE.COM> wrote:
>Ramesh -
>If your output map image is in a "lat/long" projection - which yours
>seems to be, since the extents are in degrees - then you really cannot
>put a scale bar on the map. Distances are not constant across such a
>map, and depend on the latitude and the orientation of the line you're
>measuring. A one-degree North/South line is not the same length as a
>one-degree East/West line (except if you're near the equator).
>If you want to put a usable scalebar on your map, measured in meters or
>miles, etc., you need to use a different output projection - one that is
>designed to provide such measurements.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of Ramesh Karra
>Sent: Thursday, February 23, 2006 3:26 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] How to determine the scale
>Hi,
>I have a map file with extent "74.3605 24.2590 79.5400 20.5070". I have
>a layer(with data in a shape file) with very few points
>75.23478 23.40182
>75.78261 21.90126
>76.37162 22.90461
>77.32890 20.88712
>The mapserver shows these points correctly. But it does not have correct
>idea about the distance between the points. How do I indicate the
>mapserver that these are latitude and longitudes and the distances
>should be calculated correctly? Do I need to use scale? or some other
>projection?
>I really appreciate any help in this regard.
>Thanks,
>Ramesh
