Itasca demo and Ms4w Line 44
D. Eric Keefauver Eric.Keefauver at ALTARUM.ORG
Fri Feb 24 08:38:46 EST 2006
Thank you vey much Perry!
             "Pericles S.
             Nacionales"
             <naci0002 at UMN.EDU                                          To
             >                         MAPSERVER-USERS at LISTS.UMN.EDU
             Sent by: UMN                                               cc
             MapServer Users
             List                                                  Subject
             <MAPSERVER-USERS@         Re: [UMN_MAPSERVER-USERS] Itasca
             LISTS.UMN.EDU>            demo and Ms4w Line 44
             02/22/2006 05:37
             PM
             Please respond to
               "Pericles S.
                Nacionales"
Put none in quotes ("none") and you'll be good to go.
By the way, don't forget to CC the list when replying.
-Perry
Eric.Keefauver at altarum.org wrote:
> Thanks for the additional info Perry,
> Here is the code from the map file at Line 44
> WEB
>   HEADER demo_header.html
>   TEMPLATE demo.html
>   FOOTER demo_footer.html
>   MINSCALE 1000
>   MAXSCALE 1550000
>   IMAGEPATH "set in demo_init.html"
>   IMAGEURL "set in demo_init.html"
>   METADATA
>     WMS_TITLE "UMN MapServer Itasca Demo"
>     WMS_ABSTRACT "This is the UMN MapServer demonstration application for
> Itasca County located in north central Minnesota."
>     WMS_ACCESSCONSTRAINTS none  <--Line 44
>     # change this value to match your setup
>     WMS_ONLINERESOURCE
> "http://localhost/mapserver_demos/itasca/demo_init.html"
>     WMS_SRS "EPSG:26915"
>   END
> END
> Thanks again,
> Eric
>              "Pericles S.
>              Nacionales"
>              <naci0002 at umn.edu
To
cc
>              02/22/2006 09:46          MAPSERVER-USERS at lists.umn.edu
>              AM
Subject
>                                        demo and Ms4w
> The message you got means there's some obsolute KEYWORD values in the
> mapfile.  I don't have the demo files in my computer so if you can post
> the few lines above and below line 44, I might be able to help.
> As an aside, you can certainly put the demo files under
> /ms4w/apache/htdocs.  Or you might as well follow the way it's done in
> MS4W:
> 1. unzip demo under /ms4w/apps/
> 2. create a file called httpd_demo.conf (or whatever you want to called
> it, just make sure to prepend with httpd_) and add these lines to it:
> #This is the Apache config file for the MapServer Demo application.
> Alias /itasca "/ms4w/apps/itasca"
> <Directory "/ms4w/apps/itasca">
>      AllowOverride None
>      Options Indexes MultiViews
>      Order allow,deny
>      Allow from all
> </Directory>
> 3. Restart Apache service
> 4. Edit the demo_init.html and relevant files and replace the paths with
> the proper ones
> 5. Check that the demo is running at http://localhost/itasca.
> Good luck!
> -Perry
> D. Eric Keefauver wrote:
>>New and just getting started with ms4w on my local windows machine
>>Where should one dump the itasca files to get the demo up and running:
>>C:\ms4w\Apache\htdocs?
>>I have placed the itasca data in the following:
>>C:\ms4w\Apache\htdocs\mapserver_demos\itasca
>>And within the map file I changed this line to:
>>    WMS_ONLINERESOURCE
>>At:    http://localhost/mapserver_demos/itasca/demo_init.html  and
> clicking
>>the Initialize button I get the following error
>>getString(): Symbol definition error. Parsing error near (none):(line 44)
>>what am I doing wrong?
>>thanks in advance and bearing with a complete newbie
>>Eric
