24-bit image is rendered in greyscale w hen using CLASS in LAYER
Julien, Heryk hjulien at NRCAN.GC.CA
Mon Feb 27 15:36:07 EST 2006
I submitted a bug report:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1687
BTW, when I resample my 24bit RGB tif image to 8bit, the raster is displayed
correctly.
Thanks
Héryk
-----Message d'origine-----
De : Frank Warmerdam [mailto:fwarmerdam at gmail.com] De la part de Frank
Warmerdam
Envoyé : 27 février 2006 13:37
À : Julien, Heryk
Cc : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] 24-bit image is rendered in greyscale when
Julien, Heryk wrote:
> Hi,
> When I add a class item to my raster layer my 24bit RGB tif is rendered
> in greyscale. I need the class item in order to generate a legend item
> in my ogc wms capabilities. In the following bugzilla report a similar
> problem is flagged as fixed however I am using mapserver 4.5 and 4.8.1
> and both versions have the same bug.
Héryk,
You are quite sure this is happening with 4.8.1?  It shouldn't be.  If you
can submit a bug report with the minimum mapfile and data required to
reproduce the problem I will dig into it.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
