HTML variable question
Brent Wood pcreso at PCRESO.COM
Tue Feb 28 00:20:04 EST 2006
gidday,
I have a mapfile picking up a parameter from the html from a select list, to
choose a value in an Postgis SQL to restrict the returned values. If I zoom,
however, I lose the value.
Is there any way to pass an html variable to the html template to "remember"
the selected member in the select list (without having to resort to mapscript)?
ie: HTML select returns trip=tan0601
mapfile data statement has:
select the_geom from (select * from stations where trip="%trip%") as myquery
using unique oid using SRID=4326
This works perfectly, and displays just the selected data but when I zoom,
the selection is lost. Is there any way I can set up the mapfile & html
template to retain the selected value?
Thanks,
  Brent Wood
