Web Map Context interoperability problems
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Tue Feb 28 09:23:15 EST 2006
Hi list,
I am trying to use a WMC document generated by Ionic in Mapserver, but
cannot get it to work (no layers in map object). The Ionic context validates
in Oxygen.
First problem, Ionic does not use a XML header for the context, so Mapserver
comes back with:
PHP Warning: [MapServer Error]: msLoadMapContext(): Invalid XML file
(/data/geoservices/apps/geoservices/htdocs/ionic.cml)
in /data/geoservices/apps/geoservices/htdocs/wmc_ionic.php on line 5
So I added the XML header by hand. Then the following problem occurs:
PHP Warning: [MapServer Error]: msLoadMapContext(): Unable to set units for
projection ''
Could it be that the Mapserver code assumes a 5 letter SRS EPSG code? If I
use e.g. 28992 it runs fine.
sprintf(pszProj, "init=epsg:%s", pszValue+5);
I have seen a few other potential problems in the Mapserver code:
1) the parsing code for queryable etc. assumes to get a 0 or 1, whereas true
or false are also valid values for xs:boolean
2) when outputting a WMC, Mapserver uses WMS for the value of the service
attribute of Server, whereas the OGC example (on schemas.opengis.net) as
well as Ionic use OGC:WMS
<Server service="OGC:WMS"
I have attached the context if somebody is interested to try this out.
Best regards,
Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060228/0f8d53d1/ionic-context.obj
