Strange (OVF) Query Error
Frank Warmerdam
warmerdam at POBOX.COM
Tue Feb 28 16:07:33 EST 2006
Tim Schaub wrote:
> I've noticed similarly strange behavior when running a query on inline OVF data (also with PHP mapscript - details below). My virtual layer reads from a table with a multi-column primary key in a MySQL database. I get three types of funky behavior with this:
> 1) If I don't specify an <FID> in my inline OVF, querying works as expeced until I call $layer->close() - Apache reports "premature end of script headers" only when I try to close the queried layer.
Tim,
Can you reproduce this problem in a more controlled circumstance? Perhaps
with ogrinfo? Something I could easily reproduce?
There was a problem at one time a problem with OGR virtual layers
crashing on close but that should have been fixed in GDAL 1.3.1.
Is there any chance you are using something old like 1.2.6?
> 2) If I change my primary key to an auto-numbered field and set <FID>id<FID> (where id is my auto-numbered field), I get "Unable to identify field 'id'".
This is not expected. If I could reproduce it I would look into fixing it.
> 3) If I set <FID>some_other_field</FID> then everything works as expected - even if the values in some_other_field are not unique.
Hmm, I would have expected you would get the wrong query results back
sometimes.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
