About Re-projection inside of a view.
Blammo bob.basques at CI.STPAUL.MN.US
Sun Jan 1 02:25:29 EST 2006
All,
I'm sure someone has run into this before, I have need to build a map
view with Alaska and Hawaii in the same view as the Continental US.
There will also be the need to rescale both Hawaii (bigger) and Alaska
(smaller) in the composite view.  I may even need to rotate Alaska
slightly based on the base projection (Albers)
My quandary is that I have quite a bit of data to augment if I should
need to go the route of moving/scaling everything for the two States.
Has anyone experimented with re-projecting the same dataset into new
positions on the fly, what are the performance hits etc. with this type
of process, should I even try it, and just reformat the data instead?
Maybe there is another option for viewing things side by side like this,
any thoughts would be appreciated.
Thanks
bobb
