United States City\Town\Village Shape Files???
Gary Watry watry at COAPS.FSU.EDU
Tue Jan 3 07:08:25 EST 2006
Hi
If you did not find a solution yet
Check the national Atlas
http://www.nationalatlas.gov/atlasftp.html
Download the following Shapefile layer from "Map Reference"
	Urban Areas
This will give you a polygon layer of the areas of all the towns, villages,
cities in the U.S. The only thing that is missing is the unincoorporated
townships
_____________________________________________________________
Gary L. Watry
GIS Coordinator
Center for Ocean-Atmospheric Prediction Studies
FSU / COAPS
Johnson Building, RM 215
2035 East Paul Dirac Drive
Tallahassee, Florida 32306-2840
E-Mail: watry at coaps.fsu.edu
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Adam
Sent: Wednesday, December 28, 2005 10:03 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] United States City\Town\Village Shape
Files???
I've been looking everywhere and can't find shape files for all the towns in
the United States.  I have found incorporated cities and county subdivisions
but that's not quite town\city\village boundaries.
Does this dataset exist for free?
----- Original Message -----
From: "Bob Basques" <bob.basques at CI.STPAUL.MN.US>
To: <MAPSERVER-USERS at lists.umn.edu>
Sent: Wednesday, December 28, 2005 6:50 PM
Subject: [UMN_MAPSERVER-USERS] Sort of MapServer related . . Stacked, or
coincident points . . .
> All,
> I need a way to handle a stacked point data set.  I'm working with a
> Address dataset that has some points that are stacked in the same spot.
> A few of them have hundreds of points in the same location, IE Apt.
> Buildings, etc.
> Has anyone worked with a similar dataset before from MapServer?
> We have some ideas about how to display the data.  Nothing concrete
> yet.  The current system relies on ImageMaps for the display of the
> point data via a MapServer Template.  This works for the first (last
> ImageMap record) in the imagemap, but how to view the other point
> records from the same point.   We're in the mode right now to build some
> Javascript handlers for a XML stream from MapServer, but this seems like
> overkill for some reason.
> The dataset is such that I can't seperate the different points very
> easily, nor should they I think.
> Any ideas out there?
> bobb
