ECW Support
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jan 4 14:41:16 EST 2006
If you don't mind, you could send me directly the ecw file and your map
file and I can give it a try.
Later,
Lawrence Hartpence wrote:
>I am using MS4W 1.3.0. The output from gdalinfo is:
>Driver: ECW/ERMapper Compressed Wavelets
>Size is 5000, 5000
>Coordinate System is:
>LOCAL_CS["LOCAL",
> UNIT["U.S. Foot",0.3048006]]
>Origin = (1765000.000000,584500.000000)
>Pixel Size = (0.50000000,-0.50000000)
>Corner Coordinates:
>Upper Left ( 1765000.000, 584500.000)
>Lower Left ( 1765000.000, 582000.000)
>Upper Right ( 1767500.000, 584500.000)
>Lower Right ( 1767500.000, 582000.000)
>Center ( 1766250.000, 583250.000)
>Band 1 Block=5000x1 Type=Byte, ColorInterp=Gray
> Overviews: arbitrary
>Here is the Layer Definition from the Mapfile:
>LAYER
> NAME "ortho"
> STATUS ON
> DATA "C:\orthos\orthos2005\6484.ecw"
> TYPE RASTER
> END
>I am using MapServer CGI to render the file.
>The file is around 5 Megabytes
>Thanks!
>Lawrence
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
