Map not rendering
James Net
james_marsnett at HOTMAIL.COM
Sun Jan 8 21:48:39 EST 2006
Hi all,
While I hope this is not a silly question, I fear it is, or at least would
have a simple solution.
I am trying to render a map with ms.
If I do the following, the map renders and all is fine:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=mymap
However, if I try the following, nothing is rendered - just a solid white
square:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&mode=map
I'm just using a simple map file:
MAP
NAME TEST
IMAGETYPE jpeg
EXTENT 140 -40 150 -33
SIZE 600 600
#SHAPEPATH "/home/data/map/Landsat Mosaic TM2000/GDA94LL/"
DEBUG ON
# TEMPLATEPATTERN 'start'
WEB
TEMPLATE 'start_template.html'
IMAGEPATH '/var/www/html/tmp/'
IMAGEURL '/tmp/'
END
PROJECTION
"init=epsg:4283" #required
END
LAYER
NAME "mymap"
DATA "mymap_mosaic_murray_geov2_WGS84.tif"
TYPE RASTER
STATUS ON
END
END
Is this odd? Shouldn't both URL's work?
I've also tried shp2img and the map correctly renders.
So why doesn't this work?:
I'm using map server on redhat.
Thanks in advance.
_________________________________________________________________
Make your dream car a reality
http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fcarpoint%2Eninemsn%2Ecom%2Eau&_t=12345&_r=emailtagline&_m=EXT
