ogr2ogr works on Linux, does not on Windows
Xin
crazygecko at GMAIL.COM
Mon Jan 9 08:54:44 EST 2006
I appreciate it might look a bit strange the way I've got the command
written. The idea is to convert from TAB to SHP and have WGS84 projection.
Converting with projection tags would result in non-earth projection, as
MapInfo would see it. The command seems to work with identical target and
source projections.
My problem is why does it work on Linux, but not on Windows. I'd love to
get your views on it Frank.
Cheers,
Xin
On 09/01/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On 1/9/06, Xin <crazygecko at gmail.com> wrote:
> > Hi list,
> > I am trying to convert a shapefile to tabfile whilst reprojecting it to
> > LatLong WGS84. This works great on Linux, but doesn't on Windows.
> > The command used is:
> > ogr2ogr -f "MapInfo File" address.tab address.shp -t_srs "+proj=longlat
> > +ellps=WGS84 +datum=WGS84 +no_defs" -s_srs "+proj=longlat +ellps=WGS84
> > I did initially use EPSG codes, but that didn't work on Windows so I
> thought
> > I'd try the actual datum codes. No luck.
> > There are no error produced on Windows. On opening the TAB file it is
> not
> > projected.
> Xin,
> You have told ogr2ogr that the source and target SRS are both WGS84
> so there is no reprojection to do. If the source is not already in WGS84
> degrees then you should either use a different -s_srs or omit this option
> and let ogr2ogr pick up the coordinate system from the source file.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060109/17057725/attachment.html
