Problem setting maximum extents
morgan harvey mharvey at PDX.EDU
Mon Jan 9 18:59:12 EST 2006
Hello.
I am using the zoompoint, zoomscale, and zoomrectangle methods within
PHP MapScript and am observing some incorrect behavior w/r/t the
maximum extent argument. When zooming out of the map, the maximum
extents seem only to be bound to a single axis, so that, for
instance, the minx and maxx boundaries are met, but the map goes way
over the y extents. It will consistently zoom out until the it passes
both axis constraints. All other zooming operations work properly for
me. Is this a bug within mapserver or mapscript (i couldn't find any
known bug within bugzilla) or is this the way this is supposed to work?
Here's the applicable code:
         if ($extent['x1'] && $extent['y1'] &&
             $extent['x2'] && $extent['y2']) {
                 $map->setExtent($extent['x1'], $extent['y1'], $extent
['x2'], $extent['y2']);
                 $extent_obj = ms_newRectObj();
                 $extent_obj->setExtent($extent['x1'], $extent['y1'],
$extent['x2'], $extent['y2']);
         else {
                 $extent_obj->setExtent ($map->extent->minx, $map-
 >extent->miny, $map->extent->maxx, $map->extent->maxy);
$max_extent_obj = ms_newRectObj();
$max_extent_obj->setExtent (7510802, 548620, 7827464, 783920);
$zoom_factor = -4;
$map->zoompoint($zoom_factor,$point_obj,$map->width,$map->height,
$extent_obj,$max_extent_obj);
Nostalgia isn't what it used to be.
