Best way to structure large datasets
Walter Anderson
wandrson at YAHOO.COM
Mon Jan 9 22:06:27 EST 2006
I am most interested in performance. I am interested
in minimizing the end users wait times.
I am interested in using Postgresql for the datasets
to allow for the geoprocessing capabilities that it
offers through SQL. This geoprocessing will be
separate from the MAPSERVER portions of the
applications.
--- Ed McNierney <ed at topozone.com> wrote:
> Walter -
> It depends on how you define "best". Are you
> looking for the best
> performance, the smallest storage space, or the
> easiest to update and
> maintain? The answer is different for all three.
> When in doubt, preprocess - unless your goal is ease
> of maintenance!
> If you could fill us in a bit on what your goals
> are, it would be easier
> to give more specific advice. Thanks!
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: +1 (978) 251-4242
> Fax: +1 (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Walter Anderson
> Sent: Monday, January 09, 2006 9:07 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Best way to structure
> large datasets
> I have a general question on the best way to
> structure large datasets.
> I am compiling an internal web application that will
> server GIS data to
> a small workgroup (10-20) but the data set covers
> the entire state of
> Texas. I have a couple of questions for the experts
> out there.
> 1. Specifically the road centerline data is about
> 1GB in size (1:24k
> scale centerlines). The centerline files are
> currently stored as one
> file per county (254 counties).
> I want to use Postgresql to store all of my data but
> am unsure of the
> whether I can use the tiling index method with
> postgresql or even if it
> is needed.
> 2. Also I would like to filter the roads system so
> that at the
> statewide level only the Interstates and US Highways
> are displayed, then
> as the user zooms in progressively more information
> is displayed.
> Should / can this be accomplished with a single
> (tiled) vector file or
> should I preprocess the data to generate subsets
> suitable for each scale
> level.
> Thanks for any input,
> Walter Anderson
> Walter Anderson
> __________________________________________
> Yahoo! DSL - Something to write home about.
> Just $16.99/mo. or less.
> dsl.yahoo.com
Yahoo! DSL Something to write home about.
dsl.yahoo.com
