Problem in Oracle Spatial Connection - Empty Image
Rahkonen Jukka Jukka.Rahkonen at MMMTIKE.FI
Wed Jan 11 04:23:53 EST 2006
Is it really so, that you ask this:
 http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/sdocountry/sdocountry.map&layers=country&mode=map <http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/sdocountry/sdocountry.map&layers=country&mode=map>
but in your map file there is:
NAME "CountryMap"
Have you tried with "&layers=CountryMap", or adding STATUS DEFAULT to your LAYER definition?
Regards,
Jukka Rahkonen
Lähettäjä: UMN MapServer Users List puolesta: Prema Selvam (sent by Nabble.com)
Lähetetty: ke 11.1.2006 6:28
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: Re: [UMN_MAPSERVER-USERS] Problem in Oracle Spatial Connection - Empty Image
 Thanks for the fast reply.
 Still the problem is existing, I added debug in the map file, there is no error message, only the empty image is displaying.
Map file
MAP
                DEBUG ON
                STATUS ON
                SIZE 800 600
                UNITS dd
                IMAGECOLOR 255 255 255
                PROJECTION
                        "proj=latlong"
                        "ellps=WGS84"
                END
                EXTENT -180 -45 180 45
                LAYER
                        DEBUG ON
                        PROJECTION
                                "proj=latlong"
                                "ellps=WGS84"
                        END
                        NAME "CountryMap"
                        TYPE POLYGON
                        CONNECTIONTYPE oraclespatial
                        CONNECTION "world/land at orcl"
                        DATA "shape FROM country USING SRID 8307"
                        CLASS
                                NAME "Country_Class"
                                STYLE
                                        COLOR 250 250 0
                                        OUTLINECOLOR 32 32 32
                                END
                        END
                END
        END
Thanks & Regards,
Prema Selvam.
GISbiz
View this message in context: Re: Problem in Oracle Spatial Connection - Empty Image <http://www.nabble.com/Problem-in-Oracle-Spatial-Connection---Empty-Image-t888093.html#a2313710>
Sent from the Mapserver - User <http://www.nabble.com/Mapserver---User-f1215.html>  forum at Nabble.com.
