Problem in Oracle Spatial Connection - Empty Image
Ruiter E. de (Erik) E.Ruiter at ARCADIS.NL
Wed Jan 11 08:45:29 EST 2006
you probably downloaded the standard ms4w binaries. You need binaries
compiled against oracle's oci.dll for oraclespatial support.
You can download them here : http://www.osgis.nl/arcadis.zip
<http://www.osgis.nl/arcadis.zip>
You can also check what your version supports by running the mapserv.exe
with the -v option so:  mapserv -v   through a command prompt.
With thanks to Bart van den Eijnden!
greetings,
Erik.
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Prema Selvam (sent by Nabble.com)
Sent: woensdag 11 januari 2006 14:17
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Problem in Oracle Spatial Connection
- Empty Image
 Thanks for the quick reply.
 I tried your method by passing the countrymap in the query as given
below and added the status of the layer as default in the map file.
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/sdocountry/sdocountr
y.map&layers=countrymap&mode=map
Now an error message is generated while running the above query as
msDrawMap(): Image handling error. Failed to draw layer named
'countrymap'.
msOracleSpatialLayerOpen(): OracleSpatial error. OracleSpatial is not
supported
Please support me to solve the problem.
Waiting for the Reply.
Thanks & Regards,
Prema Selvam.
View this message in context: Re: Problem in Oracle Spatial Connection -
Empty Image
<http://www.nabble.com/Problem-in-Oracle-Spatial-Connection---Empty-Imag
e-t888093.html#a2319215>
Sent from the Mapserver - User
<http://www.nabble.com/Mapserver---User-f1215.html>  forum at
Nabble.com.
[DISCLAIMER]
Dit e-mail bericht is vertrouwelijk. Het is uitsluitend bestemd voor de geadresseerde.
Indien u niet de geadresseerde bent, verzoeken we u dringend ons direct te informeren en om dit bericht en eventuele bijlage(n) te verwijderen, zonder het te kopieren, door te zenden of op enige andere wijze te openbaren of te gebruiken. ARCADIS is niet aansprakelijk voor welke schade dan ook als gevolg van communicatie per e-mail en verzending van documenten en gegevens.
This e-mail is confidential and may also be privileged. It is intended for use by the addressee only.
If you are not the intended addressee, we request that you notify us immediately and delete this e-mail, and any attachment(s), without copying, forwarding, disclosing or using it in any other way. ARCADIS will not be liable for damage relating to the communication by e-mail of data or documents.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060111/776b1676/attachment.html
