Projection WGS84 in decimal degree
Frank Warmerdam
warmerdam at POBOX.COM
Thu Jan 12 10:04:20 EST 2006
On 1/12/06, zze-SIGALE PORTANERI F ext RD-BIZZ-SOP
<fportaneri.ext at rd.francetelecom.com> wrote:
> Hi Frank & Ed,
> Thanks for your prompt and efficient answers!!!
> You're right, the pbm seems to come from the prime meridiam mismatch (and not decimal degree conversion issue as I thought before).
> I was able to confim this by manually doing some conversion tests using the Convers useful little tool (http://vtopo.free.fr/convers.htm ).
> As per example, for a WGS84 GPS point in Paris: longitude=2.38388 latitude=48.85562
> In Lambert II Etendu, I have today (wrong value) : X=775063.135566471 Y=2431242.54750943
> which is given using "Paris" as origin in Convers and which corresponds to the postgis transform call :
> psql> select public.transform(GeometryFromText('POINT (2.38388 48.85562)', 4326), 27582);
> SRID=27582;POINT(775063.135566471 2431242.54750943)
> So I have to find other EPSG values to get the correct X/Y that should be:
> X=603478.33780249 Y=2428587.76696934.
> I didn't find it yet, but I keep investigating in the spatial_ref_sys postgis (0.9.1) table!!!
FP,
I think what you will need to do is correct the PROJ.4 definition
in the spatial_ref_sys table. If you examine the +pm and +lon_0
settings you should be able to adjust things. Generally
the problem generating the proj.4 was that the +pm setting
was made *and* the +lon_0 was offset by the prime meridian
(or something like that).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
