Mapfile - 50 Layers Maximum ?
Paul Ramsey pramsey at REFRACTIONS.NET
Fri Jan 13 13:09:37 EST 2006
It's a fact that there is a limit, but it is a compile-time option,
so it is trivial to change.
Edit map.h and change MS_MAX_LAYERS to the number you want, then
recompile.  Oddly, looking at the CVS HEAD of mapserver, I see that:
   #define MS_MAXLAYERS 200
What version are you using?  Perhaps someone upped the maximum in a
more recent version.
P.
On 13-Jan-06, at 9:51 AM, Randy How wrote:
> Greetings,
> I've come across this rumor/fact, that there is a maximum of 50
> layers in a
> map file.  Unknowingly  I was experimenting the use of MapServer
> for QC'ing
> a project, that I put in 2,500 layers into a mapfile.  Yes, not
> surprisingly
> MapServer baucked about this.  Then the first question is what is
> the limit,
> then I found out that it was 50!
> I looked in to an existing mapfile that we have and it has 45
> layers.  These
> layers are represented at different scales, and/or by spatial
> reference
> (i.e. Indices for different UTM zones), then a watermark.
> We are moving into more global datasets which may be represented
> the same
> way.  There's 60 UTM zones.  So the 50 layer limit is going to be a
> problem
> in the short term.
> Can anyone verify this fact?  And is there a work around in place to
> accomplish these needs?
> Thanks, Randy
> ________________________________________________
> Randy How
> Geospatial Applications Developer
> Voice: +1-970-482-4400
> Fax: +1-970-482-4499
> Web: http://www.i3.com/
> i-cubed
> 201 Linden, Third Floor
> Fort Collins, CO 80524
