help with gml reader xerces
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Jan 13 14:02:55 EST 2006
This might have something to do with your path and whether gdal-config
is in your PATH on your system. When I build, I cite the paths, i.e.:
./configure --enable-debug
--with-freetype=/usr/local/bin/freetype-config --with
-zlib=/usr/local/ --with-png=/usr/local/ --with-jpeg=/usr/local/
--with-xpm=/usr
/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl
--with-proj=/usr/
local --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-conf
ig --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config
--with-wfs --wit
h-wcs --with-wmsclient --with-wfsclient
--with-curl-config=/usr/local/bin/curl-c
onfig --with-php=/usr/local/src/php/php-5.0.5
Hope this helps.
..Tom
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Danna Dowdy
Sent: Friday, January 13, 2006 1:52 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] help with gml reader xerces
Apache error log:
PHP Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection `/tmp/ms_tmp//11b0c7e4a83456a8a699b878cf95b349.tmp.gml'. File
/tmp/ms_tmp//11b0c7e4a83456a8a699b878cf95b349.tmp.gml appears to be GML
but the GML reader can't be instantiated, likely because Xerces support
wasn't configured in.
GDAL 1.3.1 configure options:
-./configure --with-mrsid=/usr/local/Geo_DSDK-5.0.6.955 -with-xerces
-with-ogr - with-xerces-lib="-L /usr/local/xerces-c-src_2_7_0/lib
-lxerces-c
-lpthread"--with-xerces-inc=/usr/local/xerces-c-src_2_7_0/include/xerces
c
Mapserver 4.6.1 configure options:
sudo ./configure --with-proj --with-wmsclient --with-libwww
--with-gdal --enable-runpath --with-php=../php-4.3.8 --with-gd
--with-freetype=/usr/local --enable-internal-ld-detect --with-postgis
--with-wfsclient --with-wfs --with-wcs
--with-curl-config=/usr/local/curl-7.12.1/curl-config
--with-tiff=/usr/local/tiff-3.7.1 --with-ogr
