[UMN_MAPSERVER-USERS] Group / Scale
Dave Fuhry dfuhry at GMAIL.COM
Fri Jan 13 20:19:14 EST 2006
James,
   I happen to have an example of this very thing set up here:
http://ksumap.geog.kent.edu/bluemarble/
   If this what you see there is the behavior you want, type
'marbles3' in the "Administer Site" login in the upper-right of the
screen.  Click on the red "control panel" link that appears, and click
the "Show Map File" tab.
   If you want to change the behavior (min/max scale, opacity, etc.)
of the layers, change the values on the "Modify Layer" tab, update the
layer, then head back to the "Show Map File" tab.
   Let me know if you find that useful; I am looking for ideas on how
to improve the app.
Thanks,
Dave Fuhry
On 1/12/06, James Net <james_marsnett at hotmail.com> wrote:
> Hi Again,
> So I tried the following without luck: Any Ideas? Help?
>    LAYER
>       NAME     "earth"
>       TYPE     RASTER
>       STATUS   ON
>       METADATA
>          wms_title   "earth"
>          wms_srs     "EPSG:4326"
>       END
>    END
>    LAYER
>       NAME     "marble"
>       TYPE     RASTER
>       STATUS   ON
>       GROUP    "earth"
>       MINSCALE 4000000.0
>       CONNECTION     "http://wms.jpl.nasa.gov/wms.cgi?"
>       CONNECTIONTYPE WMS
>       METADATA
>          wms_title             "marble" # DO I NEED THIS HERE?
>          "wms_srs"             "EPSG:4326"
>          "wms_name"            "BMNG"
>          "wms_server_version"  "1.1.1"
>          "wms_format"          "image/jpeg"
>       END
>    END
>         LAYER
>                 NAME    "my_map"
>                 DATA    "data/my_map.tif"
>                 TYPE    RASTER
>                 STATUS  ON
>                 GROUP   "earth"
>                 TRANSPARENCY    ALPHA
>                 OFFSITE 0 0 0
>                 MAXSCALE        4000000.0
>         #       MINSCALE        100000000.0
>                 METADATA
>                         wms_title       "my_map"
>                         wms_srs         "EPSG:4326"
>                         wms_abstract    "The map"
>                 END
>         END
> Thanks,
> James
> >From: "Fortin,Nicolas [SteFoy]" <nicolas.fortin at ec.gc.ca>
> >To: "James Net"
> ><james_marsnett at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
> >Subject: RE : [UMN_MAPSERVER-USERS] Group / Scale
> >Date: Thu, 12 Jan 2006 09:00:11 -0500
> >Hi
> >I have many layers that act like this, you only have to modify your
> >MINSCALE and MAXSCALE within the group:
> >For the high res, something like for example
> >MAXSCALE 500000
> >For the marble
> >MINSCALE 500000
> >MAXSCALE 5000000 # if any
> >Hope this help
> >Nicolas
> >-----Message d'origine-----
> >De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
> >part de James Net
> >Envoyé : 11 janvier 2006 23:55
> >À : MAPSERVER-USERS at LISTS.UMN.EDU
> >Objet : [UMN_MAPSERVER-USERS] Group / Scale
> >Hello all,
> >I have a high res raster map of a fixed extent. I want to do the following,
> >but don't know how: I want to group my high res raster with JPL bue marble
> >so that when I zoom out I see the JPL blue marbe map, but when I zoom into
> >my extent I render my high res raster map.
> >With my mapserver map file, I'm stuck here:
> >    LAYER
> >       NAME     "marble"
> >       TYPE     RASTER
> >       STATUS   ON
> >       GROUP    "earth"
> >       MAXSCALE ???
> >       MINSCALE ???
> >       CONNECTIONTYPE WMS
> >       METADATA
> >          "wms_name"            "BMNG"
> >       END
> >    END
> >         LAYER
> >                 NAME    "my_high_res_map"
> >                 DATA    "data/my_mosaic.tif"
> >                 TYPE    RASTER
> >                 STATUS  ON
> >                 GROUP   "earth"
> >                 TRANSPARENCY    ALPHA
> >                 OFFSITE 0 0 0
> >                 MAXSCALE        4000000.0
> >                MINSCALE        ??? #0.0
> >                 METADATA
> >                         wms_title       "base_map"
> >                         wms_srs         "EPSG:4326"
> >                 END
> >         END
> >Any help would be great, I've been at it all day without luck!
> >Many thanks,
> >James
> >_________________________________________________________________
> >ASUS M5 Ultra-slim lightweight is Now $1999 (was $2,999)
> >http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fwww%2Easus%2Ecom%2Eau%2F&_t=752129232&_r=Hotmail_tagline_23Nov05&_m=EXT
> Make your dream car a reality
> http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fcarpoint%2Eninemsn%2Ecom%2Eau&_t=12345&_r=emailtagline&_m=EXT
