Merging Regions of a shapefile
Neil Saunders
n.j.saunders at GMAIL.COM
Mon Jan 16 15:40:06 EST 2006
Hi Brock,
Thanks for your reply; However I've tried using PostGIS but could't
get the shapes to actually "merge" together. Ideally what I'd like to
do is have a tool such as OpenEV in to which I could load my
shapefile, select a given number of *adjacent* regions, and merge
selected regions to a single region, if you catch my drift. I'm
beginning to think that it may not be possible... :(
Thanks once again for you input!
Cheers,
Neil
On 1/16/06, Brock Anderson <banders at refractions.net> wrote:
> Neil,
> I tend to use Postgres/PostGIS for this kind of processing.
> For example:
> Load the data into postgres like this:
> shp2pgsql <loader options here> england.shp england_table | psql
> Then dump it out again into several shapefiles. Use an SQL statement to
> select the regions to include in each file:
> pgsql2shp <dumper options here> england_table "select * where ..."
> Brock
> Neil Saunders wrote:
> >Hi Folks,
> >I've got a map of England as a shapefile, containing regions for each
> >county. What I'd like to do is merge selected regions in to a larger
> >region (E.g Devon, Somerset, Cornwall etc into "Westcountry").
> >Does any one know a simple (Preferably GUI based) way of achieving this?
> >Thanks in advance,
> >Neil.
