Postgis error with mapserver
joanvp
joanvp at YAHOO.COM
Tue Jan 17 11:34:26 EST 2006
Hi!!
I've tried to show a postgis layer with UMN Mapserver. I've installed last version of postgresql with postgis (8.1). I've imported a shapefile with FME.
I've tried this layer with Quantum GIS and all works fine. The problem is with UMN Mapserver (v4.6). This is the error log
Warning: [MapServer Error]: prepare_database(): Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(geom)),'NDR'),OID::text from public.Inun_RiscAlt WHERE geom && setSRID('BOX3D(326607 4245586.875,627250 4471069.125)'::BOX3D, find_srid('','public.Inun_RiscAlt','geom') )'
Postgresql reports the error as 'ERROR: relation "inun_riscalt" does not exist '
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name> using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
This is my mapfile
LAYER
NAME inun_riscalt
TYPE POLYGON
STATUS On
CONNECTION "user=xxx password=xxxx dbname=bdmapserver host=localhost port=5432"
CONNECTIONTYPE postgis
DATA "geom from Inun_RiscAlt"
CLASS
NAME "Inun_RiscAlt "
COLOR 182 131 78
OUTLINECOLOR 4 24 93
END
END
Any solution?
Thank you in advanced
Yahoo! Photos
Got holiday prints? See all the ways to get quality prints in your hands ASAP.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060117/65d9caa4/attachment.html
