php5 Linux
Dave Fuhry
dfuhry at GMAIL.COM
Tue Jan 17 21:50:31 EST 2006
Adam,
It worked for me with Apache 2.2.0, PHP 5.1.1 and mapserver
4.8.0-rc1. After building and installing the first two from source, I
ran mapserver's ./configure with the following flags:
--with-php=/usr/local
--with-php-regex-dir=/home/dfuhry/php-5.1.1/regex
--with-httpd=/usr/local/apache2/bin/httpd
in addition to the usual. You can likely get away with installing
your distro's binary and source (-dev or -devel) packages for PHP5 and
Apache instead of building from source.
Basically use the "PHP/Mapscript HOWTO" at
http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install/#build-install-the-php-mapscript-module
as a reference and assume PHP mapscript works with php5 despite the
documentation being out-of-date.
-Dave Fuhry
On 1/17/06, Adam J Siber <siberjunk at comcast.net> wrote:
> I am trying to configure mapserver with php5 on linux as a DSO but not
> having much success? I have searched the boards/lists for instructions,
> hints, etc but have only seen a couple listings which are limited. Could
> someone please post a "how to" or some notes on this subject.
> Thank you,
> Adam
