raster maps and mapserver
Alexia81
alexia81 at EMAIL.IT
Tue Jan 24 12:27:52 EST 2006
Hi!
i recompiled gdal with grass supports and its working, i recompiled
mapserver with GDAL and now i have :
"MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG"
Everything seems to be ok but mapserv did not produce any map.
Here is the raster section of my map file :
LAYER
NAME etna
TYPE RASTER
STATUS ON
CLASS
NAME 'Digital Raster Graphic'
END
DATA "/var/www/html/grassdata/etna/PERMANENT/cellhd/boveint"
END
Thank you,
Alessia
NB : i installed a copy of mapserv in my cgi-bin directory and here mapserv
-v did not produce any output.
> Yes it is possible to set up direct grass raster support in mapserver.
> Grass support is obtained through GDAL so if gdal supports grass, then
> mapserver will too. You might be able to find an rpm for the
> gdal-grass plugin.
> If you type "gdalinfo --formats" and you see GRASS, you'll know its
> working. You can access the rasters in mapserver by setting your DATA
> parameter to "/location/mapset/cellhd/rastername"
> matt
> On 1/20/06, Alexia81 <alexia81 at email.it> wrote:
> > Hi!
> > How can i view raster map with mapserver directly from grass location
> > without creating GEOTIF images?
> > My rasters are contains float data.
> > Configuration:
> > - Fedora core 3
> > - grass60 and 61 installed from binary package
> > - mapserver-4.6 installed from binary package
> > N.B. mapserver examples are running, but ./mapserv -v did not produce
any
> > output
Email.it, the professional e-mail, gratis per te: http://www.email.it/f
Sponsor:
Problemi di Liquidità? Con Logos Finanziaria 30.000 in 24 ore a
dipendenti e lavoratori autonomi con rimborsi fino a 120 mesi clicca qui
Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=2907&d=20060124
