Turning on and off labels
Stuart Eve
stuarteve at LPARCHAEOLOGY.COM
Wed Jan 25 09:42:14 EST 2006
Right, just incase this is useful for anyone - I have managed to do a
bit of a hacky solution to turning the labels off:
I set the 'labelrequires' option of the layers to evaluate true if I
wanted the label to be drawn and false if I didn't.
Thus:
$layerObj = $map->getLayerByName($name);
$layerObj->set("labelrequires", "1 == 1");
turns the label on for layer $name.
and....
$layerObj->set("labelrequires", "1 == 2");
Turns it off.
It feels a bit of a hack, so if anyone has anything more elegant I'd be
happy to hear it.
Stu
> Thanks Norbert, thats certainly an option (which I hadn't thought of!)
> and I may do that - I was just hoping that I would be able to find a
> way to do with Mapscript (so I don't have to have such a huge mapfile!)
> Stu
>> Hi,
>> I'm not sure if this is what you want but you can make a layer for
>> the data and a separate one for the labels then you can turn them on
>> or off.
>> Regards,
>> Norbert
> Stuart Eve wrote:
>> Hi all,
>> I am trying to use Mapscript to turn off labels 'on-demand'. I have
>> my label information set up in my mapfile - but this means that they
>> are always drawn. I want to retain that information in the mapfile
>> (rather than recreating the whole thing with Mapscript), so was
>> wondering if there was a way to tell Mapserver if they should be
>> drawn or not (without turning the whole layer off!). I have tried
>> using a 'STATUS OFF' within the label tags, but that doesn't work (of
>> course!).
>> Any ideas?
>> Stu
> Stuart Eve
> L - P : Archaeology
> stuarteve at lparchaeology.com
Stuart Eve
L - P : Archaeology
