Improve performance in Mapserver on Postgis-Layer using FILTER
(workaround for the TOAST-Problem)
Leonhard Dietze
dietze at GEOINFORM.FH-MAINZ.DE
Fri Jan 27 07:38:02 EST 2006
I have several layers with rather large (detailed)
Polygon-geometries in PostGIS. While searching for
possible solutions to improve the performance of
my mapping-application I read about the TOAST-
Problem. (I am using MapServer version 4.6.1 and
Postgres 8.0.1)
After further research I read about a possible
Workaround for TOAST in PostGIS: I created a new
column in my Postgres-Table where only the
BoundingBox (bbox) is stored and use this as a
filter-attribute while selecting the geometry
(See:
http://postgis.refractions.net/docs/ch05.html#id2789728
If I do this manually, then the query only takes
40% of the time needed before.
Unfortunately I do not know if (or how) it is
possible to tell the mapserver to use this "bbox"
for the filter. If I use the parameter
'FILTER "bbox"'
in the map-file then this is inserted at the wrong
position in the SQL-Query String. The full
SQL-String can be found below together with the
explanation of the parameters.
The normal FILTER within the SQL-String looks as
follows:
"SELECT ... WHERE staat_geom_test && setSRID('BOX3D(137493 4817476,616506
5222523)'::BOX3D, 4326 );"
And with the FILTER-param from the map-file:
SELECT ... WHERE (bbox) and (staat_geom_test && setSRID('BOX3D(137493
4817476,616506 5222523)'::BOX3D,4326) );
But it should look like this:
SELECT ... WHERE bbox && setSRID('BOX3D(137493 4817476,616506 5222523)'::
BOX3D, 4326 );
Can somebody tell me if this is possible or
do I have to dig into the source code?
Thanks in advance.
Leo
FULL SQL-Query String:
- "staat_geom_test" is the column with
the full geometry
- "bbox" is the column with the BoundingBox
SELECT
h::text,asbinary(force_collection(force_2d(staat_geom_test)),'XDR'),gid::
text
from u_g1_1820 as foo WHERE bbox &&
setSRID('BOX3D(137493.827160494
4817476.39796659,616506.172839506
5222523.60203341)'::BOX3D, 4326 );
Excerpt from the map-file
LAYER
CONNECTIONTYPE postgis
NAME laender_33n_1820
CONNECTION "user=xxxx
password=xxxx dbname=hgis_germany host=xxx"
DATA "staat_geom_test from
u_g1_1820 as foo using unique gid using srid=4326"
STATUS OFF
TYPE POLYGON
TRANSPARENCY 95
DUMP true
CLASSITEM h
CLASS
EXPRESSION /2/
NAME "Länder innen 1820"
COLOR 255 235 190
OUTLINECOLOR 150 150 150
SIZE 8
TEMPLATE "templates/tpl_combined.html"
END
CLASS
EXPRESSION /5/
NAME "Länder 1820 besond."
COLOR 204 204 204
OUTLINECOLOR 235 235 235
SIZE 8
END
CLASS
NAME "Länder aussen 1820"
COLOR 235 235 235
SIZE 8
END
METADATA
"title" "Länder 1820"
"wms_name" "laender_33n_1820"
"wms_title" "Länder 1820"
"wms_srs" "EPSG:4326"
"wms_server_version" "1.1.0"
"wms_format" "image/png"
END
END
Institut i3mainz
Fachhochschule Mainz
Leonhard Dietze
Holzstraße 36
55116 Mainz
Tel.: 06131-2859-686
dietze at geoinform.fh-mainz.de
